Autor Tema: Jet Ski  (Posjeta: 7050 vremena)
Jet Ski
« u: 16 Travnja 2009, 22:38:13 »
Jet Ski, 701 ccm, 95 ks, novi, max. brzina 50 milja.
Cijena : 35000 kn
* Trailer ukljucen u cijenu
Lager : 12 komada
Ponude na pp.  ;)
Odg: Jet Ski
« Odgovori #1 u: 16 Travnja 2009, 22:44:34 »
jeli ovo Peda jet ski  :D
Odg: Jet Ski
« Odgovori #2 u: 16 Travnja 2009, 22:56:38 »
Ne, ovo je carinska zapljena pa zavladao nepotizam pa mi dali "najvecu ponudu".  :heat:
Welcome to Croatia! Legal justice rocks!   :mrgreen:
Jackie, trebao bi znati koje su ovo masine po specifikaciji.
Odg: Jet Ski
« Odgovori #3 u: 16 Travnja 2009, 23:22:11 »
A neš nam reč koja je to najpovoljnija ponuda bila ?  :think:
Odg: Jet Ski
« Odgovori #4 u: 27 Kolovoza 2009, 09:58:45 »
Pozdrav, evo gledam po netu, al nikdje ništa nema o ovoj marki i ovom jet-ski-u,
Ako neko zna nešto o njemu ili ga ima,neka javi jer sam zainteresiran za kupit...
(kakav je,kvarili se,ima li rezevnih dijelova,garancija,mašina i sl...)
Hvala!  :thumbsup:
Odg: Jet Ski
« Odgovori #5 u: 27 Kolovoza 2009, 11:17:59 »
Specifications for Jet ski
CAPACITIES/DIMENSIONS
Fuel Tank :  17 gal.(64.4 l)
Oil Reservoir : 6.0 gal( 5.68 l )
Load Limit. Riders : 500 lbs .(227kgs )
Load Limit total :  565lbs.(256kgs)
Length : 120.3 (305.6cm)
Width : 49.3 (125cm)
Dry Weight : 600 lbs (272kgs )
Hull Material : SMC*
Electrical
Alternator output : 5 amp/ 60watt@4500rpm
Ignition system : Digital CDI
Spark Plug Type : NGK BPR8ES
Spark Plug Gap : .028.(7mm)
Starting system : Electric starter
Battery : 12V.19A
COOLING
Engine cooling : Water cooled Thermostat pop off
Overheat Warning : Warning Light/RPM Limit
ENGINE
Exhaust system : Water cooled /Injected , 700H
Lubrication : Oil injected
Engine cylinders : 2
Bore*stroke : 81*68mm .
Engine displacement : 701cc
Rated Horsepower : 95HP
RPM Limiter operation :7200RPM
Intake Type : Reed Valve
Engine cooling : Water cooled , thermostat. Pop-off , self draining, direct from propulsion
Ignition system : Digital CDI , Flywheel Mag
Fuel consumption :165G/KW-HR
GAP : 0.28 in +/-.008
Idle rpm : 1300+/-100
Idle timing : 20+/-1DEG
FUEL DELIVERY
Feul type : any
Carburetor Quantity and type : 140mm
PROPULSION
Impeller stainless steel : 3 Blade(+)
Propulsion : Jet drive
Jet pump type :  Extended big mouth , single stage axial flow
Transmission :  Direct Drive
Minimum water level for jet pump : 2 feet (60cm)
Impeller diameter : 5.83 in. (14.80cm )
FEATURES
Fuel Gauge : standard
Oil level sensor : Multi-level
Tachometer : on MF1
Reverse system : standard
Voltage meter : On MFI
Speedometer : On MFI
Temperature switch : standard
Sponsons : standard,28’’
Electric bilge pump : automatic , electric with manual override .
MFI= Multi-function Instrument
SMC: sheet molded compound
FRC : Fiberglass Reinforced composite .
Odg: Jet Ski
« Odgovori #6 u: 27 Kolovoza 2009, 13:35:35 »
bla bla bla... A PROIZVOđAč ??????
Odg: Jet Ski
« Odgovori #7 u: 27 Kolovoza 2009, 14:06:41 »
Cuo sam bas neki dan pricu o ovom skuteru.Doso tip u Sunj,ponosan sa novim plovilom,sepuri se ovo,ono.Kupo se,sunco neko vrijeme i odlucio da podje ca.Kad je htio da ga upali,ovaj ne pokazuje nikakav znak.I nakon par neuspjelih pokusaja,odlucno digne sic,pa onda ispod jos nekakvu plastiku i uzme nekakav predmet ( ne znamo jeli to bio cekic ili kacavita) i pocne tuci po necemu,vjerojatno alnaseru da bi cijelo vrijeme jedna ruka bila na volanu,valjda je pritiskao pucu za start.Uglavnom upali ga,sastavi sve plastike i uputi ful gas.Nakon 10-tak metara skuter se ugasi i radnja upisana gore(znaci skidanje plastike i udarci po alnaseru) se morala ponoviti.
Ovu pricu sam cuo od covjeka koji je to sve gledao sa vrlo male udaljenosti jer smo dosli u pricu kako kako je cijena odlicna za novi skuter,cak nisam ni vjerovo da su to novi skuteri.
Odg: Jet Ski
« Odgovori #8 u: 27 Kolovoza 2009, 14:40:22 »
IME PROIZVOđAčA : FENGHUA YONGWANG VEHICLE ACCESSORIES FACTORY
2 Niksa : taj skuter ima hrpu sati rada od pocetka ljeta. Automat anlasera, uzmi kacavidu i prespoji.  :good2:
Ne kudi konja kojeg nisi jahao jer o svim stvarima se da razglabati.  :drinks:
A i taj "gospar" ima dubrovacku bolest neka i susjedu krava crkne...
Odg: Jet Ski
« Odgovori #9 u: 27 Kolovoza 2009, 19:33:44 »
i moj Kafasaki ima hrpu sati rada od početka 2006 godine...  :roll:
... pa još pali brez kacavite...  [smilie=lolroll]
SHANGRY-LA
Odg: Jet Ski
« Odgovori #10 u: 27 Kolovoza 2009, 22:10:08 »
...Zato ti retrovizor funkcionira samo sa kacavitom [smilie=lolroll] [smilie=lolroll] [smilie=lolroll]
Narocito kad se ide na duze ture :sarcastic: :laugh2: :shock: :mrgreen:
Odg: Jet Ski
« Odgovori #11 u: 28 Kolovoza 2009, 00:00:27 »
Hoce cim ti reces koliko policija placa Skode  :mrgreen:
Odg: Jet Ski
« Odgovori #12 u: 28 Kolovoza 2009, 00:50:29 »
Zato su sad Aprilijini  :good2:
Odg: Jet Ski
« Odgovori #13 u: 28 Kolovoza 2009, 12:29:25 »
I pretpostavljao sam da je kineski, ali najgore je radi dijelova (vjerovatno ih nema rezervnih), jer je sve super dok pali i vozi, a kad rikne možeš ga bacit.
Hvala na komentarima, al mislim da je bolje uzet polovnu Yamahau Xl 700 ili sl... pa i ako rikne znaš da ima servis i da je možeš napravit, zar ne ?!!?  :?:
Odg: Jet Ski
« Odgovori #14 u: 28 Kolovoza 2009, 13:06:46 »
Nije, nije ! Sad ćemo mi bombarderi ispat krivi za takvo razmišljanje !  :big_smile:
